MountaineerTom
LJ Enthusiast, Retired USAF Weapons Loader
You need to remove the snap rings. See my pic above. They are there.
Probably ought to get new washers and c clips now.What jjvw is saying is put a new johnny joint in and reinstall the bushings, washers and c-clips.
Hopefully yes. It sounds like you pressed the ball right through the bushing half and the retaining washer.Then I can just replace the internals? Brb im going to clean out the area and look for them.
https://www.currieenterprises.com/CE-9102KThis thread really makes me realize how little I know about control arms. Would you typically replace the "tube" along with everything else when doing this job? Are joints typically welded like this? Why would someone do this if not?
If I had to guess, the open end of the clip is at about 2 o'clock. See eccentric ring with the fatter part at 8 o'clock?I honestly don't see any snap rings just metal. I didn't see any on the ground either.
Look at Mr. Tough Ball of Steel over here!Please share
As long as that groove is ok, everything should be fine. Quite the picture, though!
Here's a Pirate thread about making a press. There may be better ones, but this came up right away. The goal is to squeeze the retainer washers together one way or another.
Pics of simple tool to assemble currie style JJ for those looking https://www.pirate4x4.com/forum/showthread.php?t=449534
