I'm going to answer my own question with a resounding YES!
So I bought my Jeep with 142,000 miles on it. Did the usual oil change to start and then transmission fluid and transfer case fluid. I've been driving it for a few months now and it seems to run great. This past weekend I decided to replace the spark plugs and WOW.....it runs soooo much better. The throttle response increase was pretty incredible. It seems to rev up faster and just all around run better.
The plugs that were in it were Champion and they look like the originals but I don't know for sure. I have attached photos below. They seem to be burning good but the one thing I noticed was the gap seemed really big. I installed the Autolite XP 985 per recommendations on this forum and the gap on those was much less. I also noticed that the spark plugs were VERY easy to remove, I did not need much force at all to break them loose. That leads me to believe they were not the original plugs but who knows.
Anywho, I figured i'd post up about my experience just in case anyone is not sure if they need to or should change their spark plugs. I would recommend it if you don't know the last time they were changed. The Autolites were $7 per plug and super simple to replace. My next endeavor will be the wires. Someone put some aftermarket ones on it, not sure what kind but I know they are not stock. I read that the Mopar ones are the way to go so I will be getting those and installing them in a few weeks.
Hope this helps!
Hope this helps!
