Help removing fender flares
Tylerb01
Atlanta
I just purchased a 1998 Jeep wrangler.
I am in the process of removing the old fender flares. Many of the bolts continue to spin and not back out.
Any suggestions on removing these bolts would be helpful.
You need to reach your hand up inside the wheel well and hold the plastic backing plate that they screw into. That's how you get the bolts to come out.
Those little backing plates aren't attached to the body, so they will just spin freely unless you hold them down with your hand while you use your other hand to loosen the bolt.
^^^ What Chris said. I used small Channelocks to grab the plastic nuts. It was easier on my fingers. Some were easy, some weren't.
There are a few that are screwed into metal nutserts (I believe they are some of the screws located lower on the flares), I used a needle-nosed vice grips to keep them from spinning. A couple of them on the rear are completely enclosed by the body. Hopefully they don't spin for you but if they do, you'll have to drill them out.
So I need to remove inner fender to access the plastic nuts on the back?
It makes it much easier if you remove them, yes.
I didn't remove mine though, I just pulled them back out of the way, which was barely enough to get my arm up in there and hold the plastic piece so it didn't spin. I wore thick gloves, as those things can do a number on your hands.
I remember having to remove some nut-serts on the fender wheel guards while doing this job on my 2001 Sport. As others have stated above some come out easily while some can test your nerves. Ha!
Nutserts - 3 behind each front tire. 2 in front of each rear tire. 1 behind each rear tire.
Screws and plastic nuts for the rest.
Reactions: JMT and -T.
I fought for hours to get my flares off. When I reinstalled, I used SS metric bolts and fender washers. Most of my nutserts were usable, but I didn't trust them. I had another occasion to remove my fender flares and it went much quicker.
Reactions: Okcpuckfan
When I did my flares I used a small wrench, I think 10mm, and stuck it in place to remove the bolts. The whole job, removal and installation of new ones, was a royal PITA that took me way longer than I imagined. To this day I'm not 100% satisfied with how the new flares fit but I haven't worked up the gumption to sure them up yet (and I ought to be able to).
I can't imagine how much more annoying it would be if any of the actual bolts were stuck.
I was replacing a fender and tried to take the flare off to paint it. The fender was on my work bench and I still couldn’t get some of the nutserts off. I’m planning on painting the flares and will have to mask off the Jeep when I do it. Good luck.
I just removed mine last week from my 98 Wrangler and it was not fun at all. I felt like I had gone into battle and the Jeep won (see attached picture)!
I have all 4 off and am getting ready to install some different flares (still OEM). ALL of the nutserts spun at removal and 3 of them even pulled completely out. My question is, what did you replace them with and is there a way to keep the plastic "nuts" from spinning on the rest of the fasteners?
I am about to the point of pop rivets and grind them off if I need to replace in the future. :)
83547
I used rivets, actually worked quite well and looked clean. I had to drill the nutserts out anyways so the rivets would be easier to drill out than nutserts in the future. Note: I only did this to the nutserts on the rear that you have no access to. The front I replaced with nutserts, just use antiseize on the screw threads and you shouldn't ever have the issue again.
What about the three on the front fender extensions. The front most one came out easy and is accessible from the back. The other two that are just spinning don't seem to be accessible. Any suggestions besides drilling?
And excuse the cattle waste.
What size are threads on the nutserts on the small flares on the side? (
the flat flares vs. the ones that surround the tire) I need to replace a couple of bolts...
Took my son's off a few months ago to paint flares. Videos made it look easy - it was a PITA - front came off OK, rear got painted on the Jeep. Holding the backside clips with pliers helped, but not much room inside the flare to get screws out. The rear, left on the Jeep, were painted by taping, sliding note cards between the flare and body, more taping, and holding a piece of sheet metal as I painted - turned out fine.
Reactions: Blondie70
Once you have done it a time or two, removing the flares is not so bad. The rears are absolutely harder than the front due to the plastic nuts inside the plastic inner fender. I prefer to remove them and inspect for rusty nutserts.
Reactions: madcanvis
