Recently bought a 2004 wrangler Rubicon and when I test drove it the compass/temp on the rearview worked but now its out... is this a common issue and someone knows where the loose connection is .. have checked fuses behind glovebox
I have a 04. Mine went blank. The harness in back had come looseRecently bought a 2004 wrangler Rubicon and when I test drove it the compass/temp on the rearview worked but now its out... is this a common issue and someone knows where the loose connection is .. have checked fuses behind glovebox
Thanks for the info So it wires in with the ignition... turn signal high beam switch has loose connection so I guess I'm digging into the steering column tomorrowThe mirror itself can go bad. You can sometimes have them rebuilt, or you can buy a new one on eBay. It’s a Gentex model GNTX-177 I believe it is.
It should say right on the back.
There is no fuse for the mirror.
Yes several times while driving hoping it will blink or something to confirm bad connection.. will try to trace wires tomorrow and if its getting powerHave you tried turning it on?
Nothing .. no display no lights nadaThey go bad..
Is the display lit or just scrambled lcd mess?
You can do that?
Yes, that is part of the directions in the owners manual.Did you set it up for the correct region?
https://www.gentex.com/sites/default/files/CompassCalibrationTroubleshooting.pdf
I used this when I hooked up my Tahoe mirror as a reference.
