Is Franky road worthy if something comes up?
Yep, he's roadworthy after I wash the dust and cobwebs off of him.
Got a little dusty today and went to check out the carnage from last year's devastating fires we had. Cow Mt. is BLM land designated as an OHV area. Most of it burned during last year's Ranch Fire. It was a sad day going up there to see what was left. After an hour of exploring I couldn't take it anymore and went home. I hate to see what Mendocino National will look like if they ever allow us back up there. Fire sucks balls!
This is what's left of Buckhorn Camp. From this vantage point you typically wouldn't see the campground.
The rest of the pics are on the NorCal Adventures thread if you can stomach it.
Did you get your AC fixed?
Hopefully that's the issue. Sure would be nice to avoid ripping the dash out.Jury's out on that. I took it back to the AC shop on the 20th. He thinks he found a leak on the low side of the evaporator right before the connection point of the AC hose. There is a clamp there. He removed the clamp, peeled back the insulating tape that cushions the clamp and found dye there. The clamp had worn a groove in the evap pipe, so I cleaned the crap out of it, JB welded the hell out of the area, and wrapped it in vulcanizing tape. I'm still not 100% sure this was the only leak, so we'll see in a couple weeks. It usually lasts 3 weeks before she's empty again.
Looks like they are moving right along...I didn't want to keep hijacking that other thread, so I thought I would hijack yours haha!
Here is some of the stuff I am dealing with currently, although I did manage to change my trans mount and put a transfer case cable in this week, but now have to figure out what to do with the interior.
This is currently my house now.
Yeah just a little disheartening seeing your house with x-ray vision. My work is moving buildings, and I am in a temporary spot there too, so I am constantly losing work stuff and home stuff. It is the most unorganized I have ever been. It is a bit overwhelming.Looks like they are moving right along...
Hang in there brah! You'll get thru this and be in a better spot as a result. What's the deal with your interior and the center console shenanigans?
Nice getting something done.Went to the shop today to get some things done. Wanted to un-seize my right upper CA and make a pinion angle adjustment, adjust my park brake, and install my new lug nuts. Well, after 3 hrs. I only managed to service the CA's and make a small pinion angle adjustment. The upper Duroflex joints will need replaced. After 6 years and 65K miles, they are showing wear.
Well look who showed up over here. Hey Andrew!Nice Looking Jeep you got there!
