Hey all, I was removing my rear seat brackets to clean etc. And snapped both bolts when removing. Any suggestions on how to remove remaining threads?
See if you can access them from the bottom with vise grips. Did they move at all or just snap off?
They moved and then popped. Vise grips can kinda reach but one is partially hidden by spring perch.
Don't thing there is enough room to turn vise gripsView attachment 106809
This is usually my last resort after trying less destructive methods. Screw the threads up with Vice Grips and now your day just got worse. Always begin with the least damaging method 1st.They moved and then popped. Vise grips can kinda reach but one is partially hidden by spring perch.
I realize that but there is not enough surface on the tip for the Vice Grips to get a good bite.There's a pilot on the tip of those bolts so you wouldn't mess up the threads.
There are better easy outs. I've never seen any with a built in drill bit and I don't think that will help. I could be wrong, though.
Generally, the longer they are, the better. Some are tapered squares instead of the left hand threaded ones.
Otherwise, the twisted answers for what to do about stuck bolts have pretty much been said.
Now I'll ask, what the heck were you using to remove those bolts?
I have a consumer grade easy out see pic. Is there a better version to try? View attachment 106814
X2 to the Kroil recommendation but not PB Blaster which barely works better than WD40. Kroil and Liquid Wrench came out 1/2 in a test with Break Free in 3rd place of commercially made penetrants. PB Blaster was in a distant 4th place barely ahead of WD40 which is not even considered a penetrant.Those easy outs pictured will work on broken bolts that are not rusted in like yours. If it were me I would use several different oils like kroll, PB blaster ECT. let it work for several days...
