I'll be (im)patiently waiting for your response
Keep the questions coming!
Great work. You make my fabrication skills look like I'm using crayons and toothpicks.
For onboard air for filling tires, I decided on an ARB compressor. There's many options each with their pros and cons but since I want to travel having unlimited air seems more convenient than a tank. If I were to stop in Colorado for some wheeling on the way to California or similar I wouldn't have to worry about having used too much air. I also need at minimum a small compressor for my ARB air lockers. To better mitigate some of my reliability concerns of burning up a pump I choose ARBs dual twin compressor setup, if one pump burns up the second will still function until I can get it fixed/replaced. At least that's what I have thought up in my head... we'll see how it goes in reality...
My first choice in placement is behind the driver's side tire, it'll keep the air locker hoses tidy and the noise outside of the Jeep. But it's a tight fit. If that doesn't work I'll mount it around where the fuel cell is going.
I unboxed Genrights inner fender brackets to see what I have to work with and promptly placed them back in the box. They are a bad design and half of the brackets have literally no way of fitting in; save the money and buy the fenders without the brackets. Instead, I am using MetalCloak's fender brackets (yay! MetalCloak...). You have to call for them and they cost about $50 each. I have 2 that they had sent me as replacements for my old rusted fenders but you can get away with just 1 for the battery tray or just make something similar yourself.
Here's the clearance between MetalCloak's bracket and Genright's fender. We're going to be cutting them up to make them fit.
I started by experimenting with how much I had to cut to make them fit with the fenders and innerfender:
In the end I found that chopping them into 2 parts and shortening them until they fit is an easier method.
I cut a new panel to mount the compressor onto. I drilled holes to line up with the fender and bolted it up so it'd be perfectly spaced for welding. A big thing I realized as I was making brackets is that you need to keep in mind how components will puzzle together later and in what order they'll need to be installed.
In my case the compressor will need to be slot loaded in before the inner or outer fender is installed.
Once I get to the final assembly I will be raising the breathers for the compressors up higher so water won't be a concern.
Have you turned it on yet?
Knowing what I know about compressors they like to shake and rattle. Do you have issues with the compressor vibrating against the metal of the bracket and the jeep?
Building the battery tray is really helpful to see.
I have more pictures so if there's anything specific you want to see let me know.
Heat soak gonna affect those resi? Or is that not a concern.I relocated the washer fluid bottle over to the other side of the engine.
I used:
NAPA 730-4514/Dorman 603-001 Coolant/Washer Reservoir Bottle
Continental Elite 65193 7/32" ID Windshield Wiper / Radiator Overflow Tubing
More progress:
