If you're talking about the overhead rear speakers, yeah that location sucks. I have mine dialed way down. Down so far that I only need the headunits power, and they're still dialed down. It's a horrible location. I don't use mine for added bass (I may change that with different drivers and crossover values at some point), but for added spacial sense. In other words, my system sounds "bigger" overall when they are on, but you don't notice that they are, until you turn them off.
I'd suggest a subwoofer, if you don't have one, and working on the dash mounts, as they are full of open spaces that cause the little to no bass response that everyone gets from them. If you want the sound higher up at ear level, you'll need to do something other than just the dash locations.
Not to brag, but my setup works and sounds great (parked or at surface street speeds with the top down), and isn't all that expensive.
I have an 8" slimline sub in the center console, which helps a ton, but I still don't feel like I hear the full range, like a piece is missing. It sounds good, but I feel like it could be better. I have played around with the EQ settings till I felt I had a good range. None of the preset settings sounded good to me. I'm not looking for miracles, but improvement can be had. The Polk DB's are crisp and sound good. I put foam enclosures in the dash speakers with polyfill, and added some stuffing to the rear pods as well. I used to have 6.5's in the pods, but went back to 5.25's when I purchased the Polks. I can literally tell no difference between the 2 sizes, probably as a result of having to dial them down so much.
