- Joined
- Mar 25, 2016
- Messages
- 1,272
Are those the factory fender flares? They look good!
All the ones I am looking at are sport models, so they have the hood scoop.
Good info about the ball joints. I don't want to go crazy, but I read that a 2" OME lift would be a nice lift without having to worry much about anything else. I'd also add a 1" body lift to it as well, which would probably clear 32" tires just fine.
These are the best headlights you can get from what I've read:
http://rover.ebay.com/rover/1/711-5...0001&campid=5337789113&icep_item=162353461134
They have a real HID projector retrofitted to them, so they'll be bright as hell, and have a very nice cutoff pattern. The only issue is that they're pretty spendy!
Those are factory flares.
I wanted the hood scoop too but realized they were on the sport models after I got mine. I could prob swap hoods later on.
I have 265/75/16's which are 31.5" tall. They fit stock no problem and I could fit 32's as long as they aren't any wider so you probably wouldn't need that much lift to fit that size.
By the way look for models with 16" wheels if you want to run the Tundra brakes. They require 16's.
I snapped some pictures and one of the cargo area so you can get an idea of the space.
