You'll get the vibra-jeep sorted out Brah! Don't get depressed cause that leads to bad thoughts about your TJ and they don't appreciate that. Everything kinda points to the rear end right ?
Just a thought.... Would Craig notice if his driveshaft went missing for testing purposes?As the vibration saga continues, I've been developing an increase in vibes lately. Enough that it is now irritating me, so I decided to experiment with a few adjustments. As I had expressed earlier, adding a 1" MML helped a lot with the vibes, so I decided to try lowering the t-case skid some more to yet further reduce DS operating angles. I first spaced it down 5/16" with washers. No change. I then readjusted the rear pinion angle, no change. I then took my OME 3/4" pucks and lowered it. No change. Gave up on that notion and put it back to square one. Today I decided to pull the rear DS and see if I could isolate the vibes. I could feel it in my seat above 62mph, so I figured the rear was a good place to start. Took it for a spin in FWD and no vibes. This verified what I had previously tried, it's either an issue with the DS or the rear diff. I put the DS on the bench and gave it a good inspection, and everything looks kosher. This is Adams DS #2. I'm going to check the torque on both yokes while I have the DS out. Other than that, I'm stumped. Do I try and get a 3rd DS? Do I take it to a rear end shop and have it pulled apart? I'm starting to get depressed about this whole jeep thing.
At this point, I'd let you borrow my rear axle just to see if it fixed the issues.
You could consider calling Tom Woods and talking through where you’re at. I got the sense they were pretty open to discuss drive lines and could maybe give some things to try without having to commit to buying anything more.
I’m sorry to hear about the frustrations, you’ll crush it at some point and be “Vibrafree”
Have you considered the option of adding a driveshaft balancing ring?
I still think something in the rear end setup is transferring the vibes thru the drive shaft like a tuning fork, and into my seat.
Have you pulled the inner shafts to check the bearings and the splines? You could always toss on the spare set from mine...
I saw this complete dana 44 on Facebook marketplace for 350. If you want an attempt #2 https://www.facebook.com/marketplace/item/713449265830085/
I assume you’ve tried a few degrees higher and lower pinion? Could be your rear diff
Don’t take this the wrong way, have others ridden in your Jeep and felt the vibes? Maybe your ass is just real sensitive.![]()
Have you tried removing your rear seat??? Fixed toms vibsFun fact: Did you know that your driveshaft to pinion angle relationship can change as much as 1* depending on a full tank of fuel or an empty tank? I have issues!
Check all your bolt torques (control arms and track bar) - I had a similar issue that was caused by one slightly loose bolt.I drove mine for the first time in 10 weeks since my foot surgery and I noticed a vibe during acceleration (once the tires warmed up) I checked the DS angle when I just got back and it was only .5* low, guess I’ll be crawling around under it tomorrow.
Likely it’s the same issue I had with the front axleCheck all your bolt torques (control arms and track bar) - I had a similar issue that was caused by one slightly loose bolt.
Holy s***!!! That’s pretty bad.Likely it’s the same issue I had with the front axle View attachment 143040View attachment 143041
Flat spots on the tires?? It was sitting 10 weeks..I drove mine for the first time in 10 weeks since my foot surgery and I noticed a vibe during acceleration (once the tires warmed up) I checked the DS angle when I just got back and it was only .5* low, guess I’ll be crawling around under it tomorrow.
It’s an easy fix, they just don’t like being drug across rocks.Holy s***!!! That’s pretty bad.
Only 20 psi in them, after a couple miles they smoothed outFlat spots on the tires?? It was sitting 10 weeks..
