Depends on if you're crawling Rocks or Malls, I prefer a little more side wall when crawling Rocks.
Street and old logging roads at worst.
My options are new 15" black steel wheels for around $200 and 15" Patagonia MT's for around $120 each. Or use my current 17" JK take off aluminum wheels (***with spacers***) and 17" Falken Wildpeak AT3W's for around $129 each. (I could care less about the extra $200 on the black steel rims. If it's going to give me an advantage.)
The Patagonia's are C rated 6ply. And the Falkens are SL rated 3 or 4 ply. The Patagonias get high marks in ride quality and noise. They aren't like a normal MT that is loud. The Falkens are more like a street tire with AT tread and side tread. The Falkens are probably the more refined street tire. But not as good offroad as the Patagonia. But both are C or below ride quality. Patagonia does not have a stated life warranty. I think the Falkens are 40k-50k IIRC.
I thought I would get a little more cushion out of the C rated 15" Patagonia MT's. With the extra sidewall. Which would make them closer to the Falkens in ride quality. Both tires get excellent reviews on Amazon and elsewhere. Just not sure I want to run an all black rim on my all black Jeep. Kind of like the aluminum color of the JK take offs. But that's niether here nor there. I just want the better ride and traction on dirt mountain roads in the PNW.
But I'm also having to run spacers for the JK's. And with the 15" steel wheels I most likely wouldn't have to run spacers. Which is an issue moving forward as I'm moving to WA. And they have loosely enforced fender/tire law. My spacers push the tire out well past the flares. Not super worried about being pulled over in WA. But am concerned they might inspect for this at time of new licensing.
The tire selection is based on price and availability. As the Falkens are to much in 15" and the PAtagonia's are E rated in 17". So I either have to go with the PAtagonias in 15" or the Falken in 17".
I do run low air pressure around 28-30. And RS5000X shocks. I'm also running the OEM JK tires. Which are Wrangler street radials. And they are slick as hell on wet/oily pavement. My son rear ended someone last month. And I've slid thru a corner twice in the last week. Across more than two lanes.
Patagonia's:
https://www.amazon.com/gp/product/B01EI2LQY4/?tag=wranglerorg-20
Falkens:
https://www.amazon.com/dp/B01C53C22S/?tag=wranglerorg-20
