This may seem like a dumb question but I’m gonna ask it anyway. I have a TJ with 31” tires and a 2” body lift. How can I use the small bottle jack that came with the Jeep? By the way, my TJ is a 2000 Sahara if that matters.
It reaches plenty high enough to get a 31 off the ground if you lift at the axle. I still carry mine with 32's and a 4" suspension lift. It's just not useful to jack at the frame, which it wouldn't have been on a stock height Jeep with stock tires, anyway.
I run 35" tires and the bottle jack works great to change a tire. When I wheel, I carry a cordless drill with a paddle bit and run it on the low setting. Jacks up the axle fast. I did a front passenger axle shaft swap using the factory jack.
The factory jack is tall enough to easily lift 35" tires off the ground and in a pinch, 37" tires. No matter how tall the suspension lift or body lift is since you should be lifting from under the axle.
This shows my 35" tire approximately 3" off the ground.
