Remove that bracket and hook the TB to the stock location indicated with orange. Then remove the dropped pitman arm with a pitman arm puller, Autozone rents them or they are $15.Looks good enough for me.
Seems like I need to remove that and then get the OEM one and I'm good to go. Thanks!
I suggest letting it soak in liquid wrench then tightening the pitman arm puller until very tight. Whack the pitman arm with a hammer a few times and retighten. I broke the last pitman arm puller I rented because I just kept turning it.
Also, rent a torque wrench from Autozone that goes up to 180lbs.
