TJ6?
A TJ stretched to LJ WB is nick named a TJ6 after the CJ6 model.
TJ6?
1350 u joints are bigger and decrease operating angleYes, I don't think 1350 joints have anything to do with limiting travel. I think I misunderstood Blaine, as my kids were screaming in the background (literally) over some stupid crap.
The travel will have to be limited on mine as well, as the driveshaft is so short that I expect it is going to bottom out before the shocks (unless I'm wrong)?
Check the link I just put in the last postWell I knew they were bigger, I just didn't realize that had anything to do with the operating angle.
This is one of those moments where being able to see an image side-by-side of a 1310 and 1350 u-joint driveshaft would help me visualize it.
Lol yep! Are you sure he wasn’t talking about axle shaft u joints?Based on that thread, a 1350 should be avoided at all costs
A
A TJ stretched to LJ WB but the rear pushed to the edge of the body. No overhang like a LJ and if you pushed the front forward also your approach and departure angles will be awesome.
Okay. I’d like to know as well. I’ve spent a lot of time cycling my axles during this midarm install.
With the Rancho shocks I’m near bind, still a little ways from it at full droop. My rear shaft is a TW 1310. It’d be nice to not have to run a strap but it seems like it’s in the future.
How long is your driveshaft? And which rancho?Okay. I’d like to know as well. I’ve spent a lot of time cycling my axles during this midarm install.
I’ll have to measure it.How long is your driveshaft? And which rancho?
How much are you stretching yours?
What's part number on those currie bumps. How do you dial the height in? with washers?
Depends, yes, no, not really. TJ-6 done traditionally is 108" of wheelbase. That is 40" tire wheelbase and you need the belly height to work on traditional trails other than stuff like Moab.A TJ6
Good to know, I was toying with the idea. What size do you run on yours?Depends, yes, no, not really. TJ-6 done traditionally is 108" of wheelbase. That is 40" tire wheelbase and you need the belly height to work on traditional trails other than stuff like Moab.
Neither, both, depends. What tire size?Pop quiz hotshot!
Which is better?
A. A TJ stretched to be the exactly the same as an LJ
Or
2. a stock LJ
