Here are some photos from my previous TJ's install of Savvy's 2-piece (plus an internal brace) slider as designed by mrblaine. It replaced my bent up 3/16" slider from 4XDoctor. Rounded radius on the bottom to make it easier to slide on rocks, 2-piece exterior to allow a damaged rub rail to be replaced independent of the main body, nothing to hang up on the bottom, and braced internally which significantly strengthens it. Aluminum where it can be, steel where it needs to be. No compromise design. Not cheap but if you want the best...
View attachment 30797 View attachment 30798 View attachment 30799 View attachment 30800 View attachment 30801 View attachment 30802 View attachment 30803
I see a lot of pictures of the Savvy sliders bare metal, is the steel slider actually stainless steel?
