Boggieman,
Imma thinkin that damage is not as permanent as you might believe and you might be able to restore it for just a few bucks...and some elbow equity. Test this in a small area to see if it dos the do. Important: don't do this in direct sun!
1 - Clean the areas with soap and water (don't want to be sanding the paint with dirt and dust
), then dry.
2 - Hit the area with some acetone...yep, acetone...you want to make sure you don't have polish/wax between you and the bug guts.
3 - Spray Turtle Wax Power Foam Bug and Tar Remover on the area and let it hang out for about 3 minutes. After 3 minutes or so, wipe it off with a microfiber towel and, if any major spots remain, do a little extra scrubbing.
4 - Rinse.
5 - Come back with another dampened microfiber towel and some Mothers Mag and Aluminum polish...trust me. Hit the spots of blemishes that remain to scrub them out and do a little bit of overall buffing in the whole area to keep it all smooooth. Work in a circular motion and don't let your cloth get all globbed up...rotate and/or rinse and wring out as necessary.
EDIT: Realized I left this out...let the Mothers dry to a haze and wipe off with a clean dry microfiber towel. You can then hit it with some gentle cleaner/windex and and onother towel to get rid of any residue.
6 - At this point, you should now have completely eliminated the bug marks. You can use a clay bar or some light-duty polish to enhance the shine but you should probably be good to just go for your fave quality wax and/or sealer.
Let us know how it works out!
