Running the line under the Jeep is the only practical way to do that which only requires one block. If you anchor in front and in the rear you will likely just do a sideways pull and I guess that's not really bad. With steel line it is not so difficult, not as easy with synthetic because you can snap the line on any sharp edge under the Jeep.
NoCan the TRE snatch block be used with steel cable?
I do think youtube videos are the only practical use of this technique. Out on the trail by yourself I personally can't see any situation it would be necessary. With a carefully planned recovery and a single block you can get allot done. There's a another video where Matt from Bleepin Jeep goes out and tries to find a situation to test it out and it doesn't work very well. All I really mean is I don't think it's something I'd use on the trail even if I did have the stuff.I thought the example in this video looked sound.
Watched this video the other day... very interesting... and relevant to this discussion:
This is what I have also. Haven’t used it, bu seems to be good quality.I bought this one. Haven’t used it but it seems well built. Gear America Snatch Block
Yes, just not for very long.Can the TRE snatch block be used with steel cable?
Already in the works.
Is there a way to get in on these?
No idea. I just know the machine shops and what they are working on.Is there a way to get in on these?
I asked @Garza and he just told me he would mark me down for one as soon as they become available.
It doesn’t look like they want people to be able to backorder or pre-order them.
Can you link them here when ready?We should have them ready to go no later than mid-next week.
Thank you,
Ricky
Thank you,
Ricky
