New from North Dakota: P0303 code and cylinder 3 misfire
Let me know what you find when you test the coil pack, that could potentially be an issue. At least you can rule that out pretty easily or not.
And yes, I'd still add that heat shield. I added it on my 2005 just because.
Reactions: Ian
Well I just tested my coil pack. Was not easy without someone to turn the key for me but as you can see that's for the 3rd cylinder and it's clearly a spark. My question is what now? I know it isn't a heat thing but I have no idea what to do next.
You're clearly getting spark. So have you wrapped the #3 injector with insulation as was suggested very early in this thread? I had the same #3 cylinder misfire and it took me all of ten minutes from start to finish to cure it by doing that.
Reactions: Ian and Serbonze
I put the insulator on. The code for cylinder 3 misfire isn't coming back on so that's good. But it still has the P0300 multiple random cylinder misfire and it's still doggy and you can tell it's misfiring when you get on the gas.
I've had the same issue, and even though the TSB cites cyclinder 3 I had to wrap an additional injector. At some point I'm going to get the DEI kit posted on the previous page.
Okay so I gave up on this after trying what seemed like everything short of tearing off the head. Brought it to a mechanic today and he said cylinder 3 has no compression and he just had a jeep in with the same problem and it was so bad the guy had to get a new engine. He said he could tear off the head and if it was just a problem in the head he could rebuild it all for 1800. Otherwise a new engine plus install was 4500. I limped it home and tore off the valve cover and saw nothing noticeably wrong. Tomorrow I'm tearing the head off to get a look at good old cylinder 3. Wish me luck.
Thanks for the update!
Let us know what you find once you get the head off. I had to replace the engine in my old XJ Cherokee with a new 4.0. I bought a fully remanufactured 4.0 engine long block for $2200 and installed it myself. After all was said and done, I probably ended up spending around $2800 due to misc parts I replaced while it was out (i.e. alternator). Either way, the price he's asking for a new engine installed isn't that unreasonable all things considered.
Reactions: Ian
Did they perform a DRY and a WET compression test to isolate between a head problem or a ring problem? What were the reading for each? Did they do a LEAK DOWN test which tells you were compression is be lost through? What were the results?
Not sure about dry or wet. Got the coolant drained. Belt off, alternater off, working on the power steering pump then the intake manifold. I've been told that's a huge pain in the ass but I really want that head off tonight.
Anybody know what I have to take off to get to those 4 bottom bolts on the intake manifold? I'm guessing a.c. pump but I would rather not deal with Freon if I don't have to.
You think they're hard to get out, just wait until you need to put them back in and torque them. The easiest and fastest way is to remove the front fender. I've done it several times and it's golden. Leave the headlight wiring connected and just drop the fender. Only a few bolts hold it on and then you'll have direct access to all the intake/exhaust bolts. It will save you hours of frustration for about 30 minutes of work ... REALLY!!!
I'm about to just throw on my gas mask, open the garage door, cut open a Freon line and run in the house for an hour or so. It's a jeep. I don't need a.c.
Haha, totally illegal, but I won't deny that I haven't done that before... :D
I think in your situation you have no choice but to evacuate your AC.
Reactions: Ian
