argentine pass? I recognize Gray's and Torrey's Peaks as I just hiked them last month and that's the only 4x4 road I know of that would offer a view of them.
It is
Hoping thats the case and i get my order soon. Monday will be 3wksI just ordered from them a short while back and the master install kits were on back order. They did come in and mine were shipped immediately. I didn't get any tracking either.
Revolution was initially cheaper than the set on Amazon by $200, and was told they were the better choice. Now im contemplating. Jeep goes West next weekHmm, I didn't order from them, I was able to find a good deal on the whole set on Amazon and got them delivered in 2 days. Just a thought.
What gear ratio are you looking for? What axles? Too bad your going to western slope instead of eastern otherwise I could do it for you.Looks like its time for me to cut bait and fish in a different pond. I thought going direct thru Revolution would be my best bet, apparently not.
Seeing as i have to rely on a shop doing the work for me now, i will let them choose what brand they want to utilize.
Any recommendations of a shop in the Western Slope area of CO would be appreciated. Only one i know of is Rockcrawler 4x4 in Montrose
4.56 in my stock Dana30/35 for now. Just getting my feet wet with this rigWhat gear ratio are you looking for? What axles? Too bad your going to western slope instead of eastern otherwise I could do it for you.
Good decision, that will minimize the potential for any warranty issues.Seeing as i have to rely on a shop doing the work for me now, i will let them choose what brand they want to utilize.
33s 4.0L autoGood decision, that will minimize the potential for any warranty issues.
What size tires and engine?
Ok, 4.56 is not a good choice for 33's for either of the two different automatic transmission the TJ came with.33s 4.0L auto
I just revisited the first page of this thread, someone had provided a link that Chris posted about what gears to buy. I see where i made my mistake and looked at the wrong trans. Thats where i got the 4.56 number in my head. Looked over to the first column and spied the 4.10 for my trans.Ok, 4.56 is not a good choice for 33's for either of the two different automatic transmission the TJ came with.
If you have a 97-02 TJ, that automatic is a 3-speed without an overdrive. For that you want a 4.10 ratio.
If you have a 2003 or newer TJ, that automatic is the 4-speed with an overdrive that drops the rpms by 31% at cruising speed. For that transmission you absolutely need nothing less than 4.88 but 5.13 would be ideal. Seriously.
Those recommendations are well founded, don't let some clueless 4x4 shop talk you into anything like 4.56. 4.56 would cause excessively high cruising rpms on the highway for the 3-speed automatic. 4.56 would cause the engine to lug badly at too low of an rpm with the 4-speed automatic.
Really.
You're lucky, not many shops understand how to properly select gear ratios when TJ automatic transmissions are involved.I just revisited the first page of this thread, someone had provided a link that Chris posted about what gears to buy. I see where i made my mistake and looked at the wrong trans. Thats where i got the 4.56 number in my head. Looked over to the first column and spied the 4.10 for my trans.
good catch Jerry !! Im sure a decent Jeep shop would have steered me straight, but thank you for your guidance. FWIW i did post that i was buying 4.56s on the first page and no one corrected me, so thats what i ordered. Guess it was meant to be that they never showed up.
I would have bet $1000 against your assumption. Shops don't give a shit... You tell them 4:56, 4:56 is what you'll get.Im sure a decent Jeep shop would have steered me straight
