That was the manufacturers name that I couldn't think of....
Heard good reports about Savvy products.
I think you meant "we lost weight" lol
That's like me looking for my glasses and they were on the top of my headSpent 10 minutes looking for my 13mm wrench and torx bit I keep separately to remove/install the doors. I knew I put them some place that made lots of sense but forgot what that was. I could have used a different 13mm wrench and I have other torx bits but I wanted to find those particular ones. Found them in the drivers door pocket
That read completely different and I had to re-read it as I thought you wrote Brothel hahaMy mother was raised in bothell. My uncle taught junior and high school in bothell.
Im not to worried about my soft top. Its a nos oem sailcloth.
We might head up there this coming weekend!View attachment 207074
Spent several hours driving up Nate Harrison Grade in Pauma Valley, CA off Hwy 76,
The trail is a 17 mile drive where you increase in elevation almost 4000' and end up at the back of Palomar Mountain State Park.
Gorgeous scenery with temperatures in the 40s during the day and in the 20s at night.
High idle equates to high fever must have some sort of virus?I put my jeep in the shop today. Has high idle after it warms up and cannot solve it for the life of me. Replaced vacuum lines, checked all bolts on intake, cleaned and finally replaced IAC valve but NOTHING!
So I have a local shop here that does really good work, so hopefully these guys can find what I missed.
Nice gauges.Got a little more done on the soft top install.
Could just be me but that sounded kind of, um.....High idle equates to high fever must have some sort of virus?
Did you tried to stroke the accelerator by hand at the throttle if the cable sticks?
Thanks! Was one of my last projects about a month ago. 12v unlimited panel with Marshall gauges. I cerakoted the bezel in titanium.Nice gauges.
Lol.That read completely different and I had to re-read it as I thought you wrote Brothel haha![]()
@Jerry Bransford might take offense to you using his name in vain!Well crap. Tested the winch, with fail. Apparently, something's up with the brushes as a direct jump doesn't appear to run the motor - although I was jerry rigged to the point of craziness, so I'll have to come up with a better test lashup to confirm. Of course, can't do it today...
I lost weight today. Well ok, the jeep lost weight.
View attachment 207070the black one looks very heavy
Yes, you can run the Genright rear flares without body armor. They bolt on and require drilling holes in the body. The downside is that if you take a good hit on the flare, the flare does not give but the body will.This was all from last weekend. Took off the Smittybuilt tire carrier because I was sick of how noisy it was, got this RR hinge set. I kept ping ponging back and forth on deciding between different rear tire carriers and I just couldn't pull the trigger on a $1k+ investment that may still be noisy. So I went with this... Hope I don't regret it.
Now I need to figure out what bumper to run. Was eyeballing the Savvy.
Had a gas leak problem when I fill the tank and the 'large leak, small leak' codes on the computer. Found the culprit (yikes). Replaced the hose.
Bought some Maxbilt LED taillights. Wired them up to the factory plugs. Haven't installed them yet because I needed a 1/4" 20 tap to install the fasteners and didn't have one on hand.
I'm at a crossroads... I really don't want to put my factory fender flares back on. Not only were they a pita to take off, but they're pretty beat and hideous. I really like the look of the Genright aluminum flares, but do you need the corner armor in order to install them? I don't think I've ever seen a Jeep with those flares without the corner armor as well. I wasn't really expecting to spend money on flares at this point but I think I'd rather run no flares than reinstall those factory ones.
