Hi all,
2005 LJ Automatic - 140000 miles
On my way home from work, I noticed the Jeep was stuck in 2nd gear, limp mode. After getting the Jeep home, I check the codes and read the following:
P0700- Generic trans code
P1775-Solenoid switch valve
P0846- 2/4 pressure
P0888- Trans relay always off - Less than 3 volts to relay
Along with some other emissions codes.
Checked the fluid and it was at an adequate level while running on flat ground.
I am hoping the owner of Wrangler Fix can chime in if he believes the PCM/TCM could be at fault. Anyone else seen the same codes and solved the issue?
P0846- 2/4 pressure
