Underhood light install
Vtx531
Kalamazoo, MI
I ordered a Mopar underhood light for about $20 and it came in the mail today. My Jeep didn’t come with one but it does has the connector. One of the few unused connectors on a 2002. At that time, Jeep had many differen’t wiring harnesses depending on what options you ordered.
Install was EASY! One screw (#10 x 3/4”) and I plugged it in. Just a little tricky figuring out how it went on. The mounting tab bends back so the light sits on top of it. You almost have to install it backwards at first.
Since you brought this up, I've been trying to figure out where the sensor is that turns the light on off (other than the aforementioned accelerator trigger). The light goes off with the hood about 80% closed, but I can't see anything that makes it happen, unless it's the photoelectric effect.
I didn’t look very closely but it felt like there was some type of a hinged or swinging contact switch that I could feel moving around.
This is on my todo list as well. Did the OEM part come with a bulb?
Yes the only thing I had to add was the screw. #10 x3/4. (Oem is #10x5/8) Even the wiring harness had the ziptie with the mounting tab for mounting the harness in the hole on the hood.
Reactions: Midtenn
There's a weighted switch in the wiring inside the light fixture. When the hood lifts (or you go up an incline) a steel ball rolls within the switch to close the circuit.
what a time to be alive.
Reactions: Yasha
I imagine that the light turns on and off a lot due to acceleration/deceleration and inclines.
Well now I understand this comment a lot better....if you park uphill does the light stay on?
I haven't been able to find a 2 sided led yet, the standard ones only light up one side but they're still a lot brighter than the O.E. bulb
I took two and installed them back to back so the LEDs side shine out to each side. For extra measure, I used a strand of copper wire to tie them together and to the mounting hook.
Very bright.
Very bright.
Tried that, they kept popping out of the retainers, I'll have to give it another go when I have more time
