Okay so I have a 03 rubicon. I have the Currie steering that works great. And have psc pump and box. I have the ram assist sitting in my garage and I would love to use it. But I’m not a fan of putting it to the drag link in the “y link” system I know lots of people have done it and black magic has a kit but I’m not a fan of it and already have the ram so I don’t want to have to buy a shortened one. So my question is would it be a good idea to buy either a high steer kit from teraflex. Or buy crossover steering and over the axle track bar mount from cav fab and mount the ram assist to the new track bar mount and tie rod. Or do I except I’m never going to run the ram on my tj and keep the Currie links
That's alright, I'm not a fan either. The problem is as you've noted, if you want to give up your good steering and move away from the Currie then there are several alternatives each of which has an equally undesirable answer to running assist.
If you get cross-over knuckle to knuckle with a separate draglink, you have to deal with an adapter bracket on the stock knuckle, tie rod roll from the assist cylinder, and poor brake selection.
If you get the Tera crap, yes, there is a provision for a draglink but you still have to deal with tie rod roll, and poor brake selection.
If you get inverted T, then you have to deal with tie rod roll during normal driving and with the assist cylinder.
The Currie and my hydro assist is just a simple way to accomplish something that works. It is not the best way, the proper way, or the cheapest way. It is just a way that works that the average non fabricator can do with few ill effects. Trust me, if there were an equally effective way to do it with less hassle, I would have already done it.
