Load range 'C' vs Load Range 'E' (my thoughts)
CodaMan
California Escapee
Dover, Arkansas
This is more of a comment than a discussion, so for anyone that says there is no real riding difference between load range 'C' and 'E' tires ... YOU CRAZY!!!
I just swapped to load range 'C' tires and I'm riding on a pillow now, a Jeep pillow but still a pillow :)
Edit: I went from 'E' KO2s to 'E' M/Ts to 'C' KO2s. There was some stiffness difference from the 'E' KO2s to the 'E' M/Ts, but the 'C' KO2s are a huge difference, so I would say the major difference in the ride is the 'C' rating.
E rated tires are usually heavier due to the stronger carcass of the tire. They will also be more reactive to steering input, and road disturbances.
For the record, I went from 'E' KO2s to 'E' M/Ts to 'C' KO2s. There was some stiffness difference from the 'E' KO2s to the 'E' M/Ts, but the 'C' KO2s are a huge difference, so I would say the major difference in the ride is the 'C' rating.
My load range C Patagonias were no softer than the previous load range E Cooper Discoverer ST Maxx. My current load range C MTRk's are noticably softer and nicer riding than any tire I've had on the Jeep.
That means I'm both crazy and not crazy.
My MTR Kevlar ride pretty good for a 35 inch load range C tire, but I run them at 20 psi to do so. Any more and it will shake the teeth out of your head over bumps.
Reactions: CodaMan
The key word here is “Patagonia”. No surprise there. MTRKs are a nice tire. I ran 33x12.5 for a few years as a DD. Eventually they will behave like every other m/t and start to get loud, but I think the hybrid tread pattern definitely helps.
