My ASD relay goes back and forth a bunch of times for about 5 seconds and then goes off when I put the key in the accessory position. But then when I tried to crank it I get nothing
Take a look back at posts 17 and 18. That’s what needs to happen if you haven’t started troubleshooting your fuel system yetI had the battery load tester today and they said it was fine
No, I don't. I had one in my old Wrangler but I looked in this one and it does not have any extra wires like my old one did. I mainly confused on why the ASD relay would go back and forth so much? I mean it's not blown so I don't know how to go about bypassing it if it's not. Any ideas what could be triggering that clicking?
Well I finally had a mechanic come take a look at it and he tried to plug in his scanning computer and could not get any reading and told me that I needed a new PCM. I've been looking all over but haven't found one that I can afford yet. I have heard from a couple different places that a 2006 manual transmission computer is one of the most expensive because it's one of the most rare to find. Just my luck.
So when you talk about a buzzing/clicking relay that makes me think you have an electrical issue. If you have corrosion/loose wires/bad connection on the control side of a relay the coil won't generate enough power to hold the switch side closed. It can click over and over like you're talking about or make a buzzing noise.Hey everyone just an update I could really use your help I have replaced my PCM my battery Mike crank and camshaft sensor and still cannot get my Jeep to start. when I turn the key to the accessory position all the gauges come on headlights work radio works, but there is a strange buzzing sound coming from the ASD relay and when I go to start it, I can get it to crank but never start. Does anyone have a suggestion or has this happened to them and how did they resolve it? I'm pretty much out of money now and don't know where to go from here. Like I said this is my daily driver and it's killing me because I can't work which of course leads to greater stress. I know there's someone out there that this is had happened to that might be able to help. Thanks in advance
Hey everyone just so you got a better idea of my issue, I made a video of myself trying to start it but was not able to post it on here because the file size was too large so I posted it on YouTube and here is the link that you can click on to view the video. Any thoughts or suggestions would be greatly appreciated:
I thought the same. Sounds like the starter solenoid was struggling to engage, another symptom of low battery voltage. Low voltage can be caused by a bad battery (obviously) or corroded cables/connections.Have you checked your voltages with a VOM? A fully charged 12v battery should read 12.75 VDC. 12.4 VDC is only 80% charged.
The way the starter was chattering before you got it to turn over sounds like low voltage. Low voltage can also cause relays to chatter. How are your battery cables? I've had battery cables look fine, but be corroded internally.
BTW, you have comments disabled on your video.
That's your ignition coil capacitor. I don't think it has anything to do with your current issue, but you can replace it for about 10 bucks.Could someone explain to me what could be causing my ASD relay to click open/close a bunch of times for about 5 seconds and then go off? I also hear a buzzing noise as well whenever I put the key into the on position. Also I looked on my old Wrangler and notice that this part has broken off of my engine on my current one. I'm guessing this is some sort of a ground but to what I have no idea could someone please elaborate? I'm including a couple pictures of the piece that I found dangling and where it came detached from the engineView attachment 219371
