Does anybody have round LED tail lights?
looks good so far, can't wait to see how it finishes up.
i found those 1's DrD posted oh so long ago on Amazon for $35 ea. kinda like how the whole lamp goes both colors, the BU light is bright. add in grommets and 3 prong pigtails it's about 82$.
guess i'll have to get over drillin a big ass hole into brand new armor.
Reactions: DrDmoney
I finished my setup last weekend. Total cost $80 including license plate setup
Something I don't understand though is that my third brake light blinks with the right turn signal. they are not wired together. I still need to replace the flasher relay.
Thoughts?
With all the cutting you need to do on the noncut corners you have a 4.5" hole is nothing.
you got me there. but i could make a 1/4" mistake on wheel well openings and most could never notice, your never gonna be seeing both side at 1x.............now cock eye'd taillights. would be obvious to most.
i just might have enough room to get behind and center on the old holes, like y'all did. and poke a pilot out so i don't goof it. if it looks even a MM off it'll bug me beyond mention.
Reactions: DrDmoney and Alex01
you got me there. but i could make a 1/4" mistake on wheel well openings and most could never notice, your never gonna be seeing both side at 1x.............now cock eye'd taillights. is some ridin the short bus window licker stuff, and would be obvious to most.
That would work. Since my tub was already cut I just reached up and outlined the holes onto the savvy corners once they were mocked up. Centered the best I could off the marks, then after reattaching the corners ground the 1/16 or so I was off to make them both flush. If you decided you want to make the cut down the line I'd be happy to get some measurements for you.
Reactions: DrDmoney
ATM i really just needed the bottom line off of the corners. so i could confirm the rocker panel lip measurements. once i get that BS finished, i'll start the surgery on the new stuff based on the wheel and if i can keep that location or have to go up or in with the lamps.
If you want you could PM me with some points you want me to measure, so I remember, and I'll do it later today when I'm near the jeep.
Reactions: DrDmoney
Somethings not perfect in the wiring, since I don’t have running lights, so I need to go in one more time and move something around. They work when I turn on the parking lights. Turned out good. Way better looking than those stock things, way brighter too.
and then i can't find details on most grommets, are they just pressure fit into any hole or do they have a designed grip range?
to me a grommet has a flange on both sides and a designed grip range between those sealing flanges. these things for the lights appear as pressure fit flanges and not true grommets, is this true or am i off somewhere?
The grommets have a small lip on them but the light expanding in the grommet also aids in its retention. Most of the grommets will handle sheet metal to about 3/16 thick.
i hope i'm 3/16 armor + sheet metal.
i'll keep an eye in here and bump the thread again, when i get ready to move on these.........i appreciate the offer.
Reactions: Alex01
For those running the led taillights with integrated reverse lights , does your reverse lights come on at all with the key on ?
Mine come on with the key on , they are dim and barely noticeable, other than that they work great. Maybe they have always been like that and I just never noticed until today in low light.
I put a new clutch in this weekend and buttoned everything up today other than disconnecting the reverse switch I haven’t changed anything. I have the lights for over a year now and they have always worked great.
