only if it "spits flames and pops"Dana 80. Super swampers. Flames coming out the tail pipe.
It’s all good bro!Yeah, she really adds value to the process. Almost knocked the axle off the jackstands a dozen times, then managed to fling gear oil all over me more than once. Also every bolt somehow ended up in the bucket. It's all good though.
I'm putting your ammo in the mail tomorrow, I swear.
Give the skid plate a washer or two to create a nice air gap. Doesn’t have to be big, just enough to keep water from being trapped in between the two surfaces.Another note - I was REALLY surprised at the amount of rust at the skid plate union. The rest of the frame has a little surface rust here & there, and everything is is almost perfect. Haven't had a single issue up unit this point, and this particular part of my frame really looks like shit.
I'm going to change out all the nutserts when I get the get the kit from Blaine, put a wire wheel over all of it, & put in some drain holes.
97-02 have two tacks, 03-06 do not.Another question - do the factory skidplate nutserts typically have tack welds? I already ordered a new set from @mrblaine , but I noticed today after wresting the skidplate off that all the existing nutserts have two tack welds each spaced 180 degrees apart. Is that normal or did the PO do something hinky?
For future reference, though it probably wouldn't have helped you, I've had a fair bit of luck getting bolts loose by starting to tighten them first. Especially one in a nutsert. A little extra torque can help reseat the nutsert and help it hold just a little bit longer.In the latest episode of "why the fuck am I doing this", I spent the whole morning getting the skidplate off.
I was able to zip out the right front bolt no problem. The other bolts on the right side were being tough, but they were coming. The left front bolt was just spinning, so I'm guessing the nutsert broke. Ground the head off of that one.
The other two left bolts were really being bastards about it, I mean really difficult. When I took a step back to think about what the hell was going on I realized my skidplate was bowing down over the little jack stand that I had set in the middle for support. Looks like the TC drop spacers installed by the PO were so thoroughly rusted to the bolts that they were forcing the skid plate down with them instead of letting the bolt drop through.
Likewise, the bolt that I cut the head off of had the same problem. Even though the bolt head wasn't there the rest of the bolt was stuck in the broken nutsert and the shank was stuck in the spacer. I was getting really annoyed. I moved the jackstand out of the way & got the skid plate loose just dangling from the one headless bolt by rust from the spacer. Took about a half hour of persuasion with a torch, prybar, & impact hammer to break up the rust & let it fall to earth.
Now I have a skidplate on my garage floor with four spacers rusted to the bolts and one still hanging in the frame. I'm either going to melt them off or just buy a new skidplate.
From there I went ahead & started on the SYE. I elected to leave the TC in the truck because it's up high enough for me to sit there & fiddle with it. The instructions that came with the Advance Adapter kit are great, and it's a very straightforward job.
Everything went fine up until the point of installing the new snap ring behind the mode hub. Couldn't find it. Searched & searched, who knows where the hell it went. I unpacked the box like 3 weeks ago. I tried the old one but it got mangled to hell being removed by my shitty snapring pliers & a screwdriver, so that wasn't happening. I called Tom Wood's, spoke to John, he said he'd grab one for me and it would be sitting on top of my original invoice on the file cabinet to the left of the office door. Free of charge, just come grab it. That place is awesome.
That works for quite a few. The problem versions are the ones that rust the nutsert barrel to the bolt and then that twists off from the tack welded flange. It won't tighten or loosen, just spins and they suck.For future reference, though it probably wouldn't have helped you, I've had a fair bit of luck getting bolts loose by starting to tighten them first. Especially one in a nutsert. A little extra torque can help reseat the nutsert and help it hold just a little bit longer.
Yup...if it's spinning, you're gonna hate life for a while.That works for quite a few. The problem versions are the ones that rust the nutsert barrel to the bolt and then that twists off from the tack welded flange. It won't tighten or loosen, just spins and they suck.
So is there a need to put a couple of tacks on there with the new ones from your kit? Curious as to why they stopped tacking them.97-02 have two tacks, 03-06 do not.
The tacking was so they could set the nutsert. They must have changed the tooling to set them that did away with the need to tack them.So is there a need to put a couple of tacks on there with the new ones from your kit? Curious as to why they stopped tacking them.
I can see that. If I was working overhead instead of on the ground it would have been hard to keep the nutsert flush to the frame while turning the nut. I used my knee to keep the stackup against the frame while turning the nut for the first rotation or so. If it were up in the air that would have been tough to do.The tacking was so they could set the nutsert. They must have changed the tooling to set them that did away with the need to tack them.
Speaking of, what's the best rattle can paint to spray over the bottom of everything I ground down?Next step is to paint the frame around the new nutserts, install the skid, & then start on the rear axle install. Should go perfectly.
Krylon rust tough preventative enamel is really good and strong.Speaking of, what's the best rattle can paint to spray over the bottom of everything I ground down?
