Like others have said, it finally warmed up so we might as well fix the crap that broke during the cold weather.
The check engine light came on the way to work, went to work then home and parked it. Started it up today, idle was junk, stuttered under throttle and no power. i figured the throttle body was a good starting point....finally got lucky for once. The TPS was loose, clipped it back together and done.
Also found a pesky vacuum leak while in the area.
Cold weather sucks, bring on spring time!!!
