Did you move those too or just the TB mount? Also nice work BTWThanks! Much easier to do than the front shocks and moving the upper springs seats are.
So far, I have moved the driver's side upper spring seats along with the shock install. Passenger side is this weekend.Did you move those too or just the TB mount? Also nice work BTW
Interesting, they did look more angled back in the before pic, did your lift height change?So far, I have moved the driver's side upper spring seats along with the shock install. Passenger side is this weekend.
That looks cool, JJ. You Coloradans have all the fun...The annual April Phoolz run in Buena Vista, CO is happening. See here!
https://wranglertjforum.com/threads/april-phoolz-buena-vista-april-3-2021.47688/
I was playing a lament since his Jeep is too far gone.... When he gives up on it I'll send it off to Jeep heaven with amazing grace...Day 2 of the passenger side
With as much time as jjvw spends in the shop I'm considering changing the name to the jjvwgarage.
You’ll have to show off the Pipes & Drums under the work bench.With as much time as jjvw spends in the shop I'm considering changing the name to the jjvwgarage.
I know who won't be subscribing to my competing YouTube channel.That’s a terrible name.
Finally finished after two solid weekends! This is the hardest modification I have done to the Jeep. A rear outboard is much easier. But the Jeep has never driven better.Are you wrapping it up at least?
That’s an awesome shop you have there, @hosejockey61. And very cool from the outside as well.With as much time as jjvw spends in the shop I'm considering changing the name to the jjvwgarage.
