how about you go all out and go with some walker evansI plan on a set of centramatics in the near future. Should help a bit
Centramatic 200221
These are the ones I have, you should get the next size up. Which are what josh has
Mine are 13" diameter, right?
The only thing in those pics that hasn't changed is that Centramatic!
Same here. I see conflicting information on beads, but these seem to get better reviews.Interested to see how well those work for you.
I have tried beads in 35" radials. It did not work well at all, they would smooth out and then hit a bump and come out of balance and take a while to come back in.Same here. I see conflicting information on beads, but these seem to get better reviews.
Taking advantage of the poor weather
View attachment 233851View attachment 233852View attachment 233853
It's my painting booth!ay whats with the rug to stop paint from getting to the walls that need painted???
i hope you have better luck than i did , the paint flaked off mine in big patches, it never adhered.
Been running them successfully for 15 years in both the 295/75r16 and the 35x12.5r18's on my F250 and they're glass smooth all the way up to the 100mph limiterI have tried beads in 35" radials. It did not work well at all, they would smooth out and then hit a bump and come out of balance and take a while to come back in.
My opinion on balance beads is they are a BIG tire only thing, where they are better than nothing. I'm talking 38-40"+ range. I run 10oz of beads in some 38" bias swampers. They seem to do stuff at highway speed and smooth it out a little. I'm sure smoother than if nothing at all. To be used as a serious balance method they stink. They are for tires that cannot be balanced with weights.
Again, my experience and opinion.
Scotch Brite pads and acetoneDid you do much prep on these? I still need to think about doing mine eventually.
