Gonna body lift it? I'll have 6 savvy picks here in the next couple weeks. You're welcome to them. That will leave you to locate 5 more, but with as many people as are lifting the rear cross member, it shouldn't be hard to find.
I got 6 pucks from @Alex01. 2 for the grill and 4 of the normal. That means I need 5 more (I think). 😁
Reactions: Alex01
You need one for the grill in the center of it. Then 6 for the body mounts in the middle unless you do the raised mounts and then 4 for the rear. 2 on the shock crossmember and 2 for the very back unless you eliminate the butt crack.
Reactions: DrDmoney
i think the two you're thinking of are the extenders for the little rubber bumpers
Yes, I have the two small ones. I forgot the ones on the shock crossmember that @Wildman mentioned. So, I need 7 more. I’ll be close if @Mike_H Pitches me 6. Just 1 away.
You need 11 body pucks total and then the 2 little snubbers on the front edge of the nose.
If you do the raised body mounts then you only need 5 body pucks and the 2 snubbers.
You just need to know someone with a welder. And a plasma cutter helps to take the old body mounts off quicker. But a sawall works too.
Reactions: JMT and Alex01
Only needs 3 if he does a BCE 😉
I got my cross member raised today. I'll give a count tomorrow. Pretty sure I have at least 6. The grill ones will be the sticker.
Reactions: Alex01
@jjvw handled this. Chop and flip the ends of the cross member and weld a bit you cut off from the C to the frame to bolt to, it’s really clean.
That makes perfect sense. Thanks.
Mystery box showed up today. Wonder what’s in this one? It’s for my TJ.
got a small shop press? get them boys a sheet of steel and a hole saw and let um get at it.
this was the cut away Savvy bracket i hung the UA from inside the frame. just added a few small gussets. i also poked through jjvw's and toximus' threads for info on this.
