Maybe @NashvilleTJ thread. IDK. Page 4 in his thread is where he installed them.
I don't think it was in his thread.
I remember this thread covering the Swag Bertha’s
https://wranglertjforum.com/threads/has-anyone-used-swag-bertha-raised-body-mounts.45254/
I got 6 pucks from @Alex01. 2 for the grill and 4 of the normal. That means I need 5 more (I think).Gonna body lift it? I'll have 6 savvy picks here in the next couple weeks. You're welcome to them. That will leave you to locate 5 more, but with as many people as are lifting the rear cross member, it shouldn't be hard to find.
I got 6 pucks from @Alex01. 2 for the grill and 4 of the normal. That means I need 5 more (I think).![]()
i think the two you're thinking of are the extenders for the little rubber bumpersI got 6 pucks from @Alex01. 2 for the grill and 4 of the normal. That means I need 5 more (I think).![]()
You need 11 body pucks total and then the 2 little snubbers on the front edge of the nose.
Only needs 3 if he does a BCEYou need 11 body pucks total and then the 2 little snubbers on the front edge of the nose.
If you do the raised body mounts then you only need 5 body pucks and the 2 snubbers.
You just need to know someone with a welder. And a plasma cutter helps to take the old body mounts off quicker. But a sawall works too.
Only needs 3 if he does a BCE![]()
I got my cross member raised today. I'll give a count tomorrow. Pretty sure I have at least 6. The grill ones will be the sticker.
What do we do with the inner C’s on the Savvy MUA system? Seems like they would conflict.
That makes perfect sense. Thanks.@jjvw handled this. Chop and flip the ends of the cross member and weld a bit you cut off from the C to the frame to bolt to, it’s really clean.
I’d link the posts but you’re probably familiar with how detailed his thread is. As a rough time frame I think it was last summer or fall.That makes perfect sense. Thanks.
I found it. Thanks...I’d link the posts but you’re probably familiar with how detailed his thread is. As a rough time frame I think it was last summer or fall.
You tease
