When my jeep was new to me (stock non-rubicon unlimited on stock size ko2s), my brother and I took it out to a local recreation area (the kind that suites atvs and utvs with all sorts of dirt roads, hills, and obstacles everywhere going nowhere). We had been there several times before in his lifted xj (on 33s) and there were these steep hills we would always attempt to climb but could never make it up (tires would start spinning out 1/3 of the way). The only vehicles we ever saw make it up these steep, loose hills were long wheelbase razrs. When we took my stock unlimited, we were amazed to find that I could easily drive all the way to the top of these hills with no drama whatsoever. It wasn't even a challenge.
My jeep is now on 33s and savvy short arms with 3-ish inch springs and to make a long story short, I have not made it up those same hills with my new setup. The tires spin easily and the jeep bucks around a bit.
There are much wiser members than me here that can explain what happened in this situation I just shared but my take away is this - factory control arm geometry is desirable for steep climbs.
I purchased a set of Dave's geo correction brackets because they seem very promising with their function of bringing the control arms closer to factory angles in a short arm lifted application (btw I don't care or buy into all the other fluff regarding wheel arc, rear steer, etc.). The problem is they are very tall and after some preliminary measurements it has become clear to me that I won't be able to maintain the 6" of up-travel I worked hard to achieve. For now they are sitting on a shelf and I may shorten them 1 inch and do a modified install without re-drilling the frame side lower control arm mount. Maybe. In the mean time I have to decide if all that work is worth it and if I will ever realistically take my jeep places where control arm geometry really counts.
