DETOUR
I do agreeLuke is definitely an overachiever
Maybe I can lure him up to mile zero Alaska highway for a bit of assistance
I’m running waaay behind on my “list”
lol
You keep riding around in your rattling tin can then lol, the sound deadening in the jeep undeniably has helped with noise reduction and stopped all of those annoying interior vibrations that TJ's have. Sound deading the entire tub has been a badass upgrade imo, at least for what I use my rig for.What's the point of doing that on a convertible, if you don't mind me asking? NOTHING reduces noise on a TJ, including hard tops. I've had several and they aren't quiet and don't keep heat in any better than a soft top. They're good for one thing, $500-800. That's it.
The dog looks maltese ish..what is he/she?Finished installation of the Noico sound deadening material and got the front Bedrug put in this weekend. My supervisor wanted to be in the photo....
Also bit the bullet and ordered the rubber floor pan cover since mine had multiple tears/holes. This should also help with the sound being transmitted into the cabin...
Painted the half doors, a lot of doubters on if a rattle can could knock out Bright Metallic silver effectively. I’m pretty flipping happy with the results. View attachment 252415Washed
View attachment 252420Roughed up
primed
comparing to the full door from factoryView attachment 252418
And the VerdictView attachment 252419
Cleaned er up and took it to the mall!My mom laughed when I pulled up in the Jeep to my folks place for Mothers day haha
‘Looks nice!I had a Ramsey Patriot 9500 winch sitting in my garage for a long time. It was originally mounted on my 2000 TJ.
It looked like shit. The powder coat was peeling. The aluminum mounts were all corroded.
I disassembled it, cleaned it all up and put a nice coat of gun metal grey paint on it.
I even ordered new decals.
I didn't really expect it to work due to the condition it was in. Well here it is, looking almost new, and it does indeed work.
Just waiting on new line and a fairlead.
I’m with you but this reminds me of my days of car audio where people would fill their doors with concrete to get a better sound.What's the point of doing that on a convertible, if you don't mind me asking? NOTHING reduces noise on a TJ, including hard tops. I've had several and they aren't quiet and don't keep heat in any better than a soft top. They're good for one thing, $500-800. That's it.
Synthetic‘Looks nice!‘You gonna use cable or synthetic line?
My tin can doesn't rattle at all and if it did, I wouldn't hear it with my 1200w stereo turned up or my even louder wife.You keep riding around in your rattling tin can then lol, the sound deadening in the jeep undeniably has helped with noise reduction and stopped all of those annoying interior vibrations that TJ's have. Sound deading the entire tub has been a badass upgrade imo, at least for what I use my rig for.
How did you determine it's a 9500. I have a Mopar branded Ramsey and I can't find any decal, tag, or other that indicates it's poundage.I had a Ramsey Patriot 9500 winch sitting in my garage for a long time. It was originally mounted on my 2000 TJ.
Radio delete is where it’s atMy tin can doesn't rattle at all and if it did, I wouldn't hear it with my 1200w stereo turned up or my even louder wife.![]()
For whatever reason, I didn’t take you as being old enough to be a grandparent. But cool enough.Finished up the passenger side rear UCA. It didn't go in as easily as I expected, it needed some pre-load. Of course, I had two sizes of pry bars - way too small, and way too big. After cussing at it for awhile, I had to go pick up my granddaughter from school, so I stopped off at Ace and found the perfect pry bar - just the right length and WIDE - so it would push on the metal, not on the rubber. It sure is nice when you have the correct tool - the second bolt that wouldn't line up on the UCA went right in. Easy-Peasy.
Then I drilled a 1/2" drain hole above/behind the LCA bracket on that side, and rinsed the frame out with water. Coarse sand, fine gravel, and a bunch of shiny silver metal flakes from the drilling operation came out. Looked like a gold pan - except it was silver. Since my Jeep is an '06 manual, it already has a suitable drain hole in the front area.
Will hit the new hole with red lead tomorrow after it dries out overnite, then on to the other rear UCA. Now that I know how to do it, it "should" go faster...
I'm technically old enough to be a great grandparent! Its amazing what a little henna in the hair, and some makeup will do for a fella!For whatever reason, I didn’t take you as being old enough to be a grandparent. But cool enough.
I purchased it brand new back in 2000.How did you determine it's a 9500. I have a Mopar branded Ramsey and I can't find any decal, tag, or other that indicates it's poundage.View attachment 253111
Thanks, oversanded the clear coat in a few places and went through, but no one will notice but me. For two guys and a garage it’s a job well done!Great work!!! Turned out good.
