Did you have to do any nutserts for the tub armor?I took off the pilot on my rotabroach. The holes in the slider worked as a guide for my RB similar to drilling the holes out with a drillbit and it worked perfectly. I couldn’t imagine installing all the shit I did without an RB
One thing I noticed since installing the new sliders - we pulled back some damaged tub.
Negative, I just never noticed it before today. It’s not a common spot I get in other pictures!Uh-oh better get maaco! Do you have before and after pics?
I like those. What brand are they?
I have used both a tool from Amazon and the standard nut tightening with a sleeve/bearing. the nut way seemed to be a bit more reliable.How are you setting the nutserts?
My Mustang dead pedal only uses two big sheet metal screws. Yours should work just as well.I finally got a dead pedal in, which I think will be nice on longer drives.
Since I didn’t want to cut up my all weather floor mats I customized the dead pedal instead. It seems strong enough without the floor support.
Is the tailgate plate different than the corner armor?Delete. Tail lights next and deciding where to put the plate, thinking below the tailgate in the middle.
I went with Genright like the corners hoping it would match - I need to check it in different light but that picture definitely doesn't look to match (which would be very irritating, but so far I am not loving GR stuff). Annoyingly their valence piece has a GR logo in it, so I won't use that one if I do that piece too...Is the tailgate plate different than the corner armor?
For your license plate, pick up a swayloc too
https://offroadonly.com/shop/led-li...late-led-light-with-6-disconnectable-harness/
