That explains a lot then, halogens will never be an equal or even decent replacement for LED's, no comparison.
For now these seem better than my OEM so ill gladly spend $50 and wait to add $500 LED
That is why I said in the first sentence and the title of the thread that they are a nice alternative to LED headlights. Also the several photos show h4 bulbs and I mentioned h4 bulbs a few times. I tried a set of trucklite led's in this jeep that I borrowed from a friend and I just didn't like the look though the light output was very nice. I am not a fan of the super bright white light LED's emit.That explains a lot then, halogens will never be an equal or even decent replacement for LED's, no comparison.
Any h4 bulb should fit. The Ih8mud thread I linked he tests several different bulbs and one led bulb. The best pattern actually seemed to be the stock Koito bulb based on the photos. The LED bulbs in an h4 housing tend to throw light all over the place. I ran an LED bulb in a square h4 housing for a while on an old pickup and the pattern was pretty crummy. But I have not personally tested an H4 LED replacement bulb in these housings.Will beamtech led fit these?
ThanksAny h4 bulb should fit. The Ih8mud thread I linked he tests several different bulbs and on led bulb. The best pattern actually seemed to be the stock Koito bulb based on the photos. The LED bulbs in an h4 housing tend to throw light all over the place. I ran an LED bulb in a square h4 housing for a while on an old pickup and the pattern was pretty crummy. But I have not personally tested an H4 LED replacement bulb in these housings.
I agree with the OP that LED’s just look “off” on a TJ. And my wife thanks you for putting something on the board that I didn’t know I needed!![]()
I think the harness that comes with this kit is nice. It definitely has heavier gauge wire for the hot feeds to the sockets and to the battery and smaller gauge wire for the signal wire feeds. Koito is OEM for a lot of Japanese manufacturers. So I would think the quality is there. It certainly seems to be. The main power wire does seem to be at least 14 gauge.In regards to the wiring harness that comes with this kit: I’m not going to trust those $20 harnesses to last. If Toyota is selling this kit though, I imagine it’s just as good as the ABR M002 harness that costs $140.
https://www.quadratec.com/products/97018_2430.htm
Correct. The stock TJ sealed beam headlamp has the same 3-prong connection as an H4 bulb so the headlamps and H4 bulbs are plug-n-play.You cant even find H4 housings for that cheap! I'm assuming that there's no need for all the wiring when implementing in a TJ though, correct?
They’re in the Ih8mud thread the OP linked twice.Waiting for after dark pics, then I'll probably put in a order too.
Ok, I'll check back again. Was having a hard time getting any of the pics to load the first time I looked.They’re in the Ih8mud thread the OP linked twice.
See posts 58 & 59 in that thread for a comparison with a few different bulbs.Ok, I'll check back again. Was having a hard time getting any of the pics to load the first time I looked.
Same here. I originally had two LED spots and a LED bar on the front of The Muddog, and it made everything look like an overexposed picture. I replaced them with two pair of halogen lights and found that I could see better with them.I am not a fan of the super bright white light LED's emit.
Was also gonna ask. I was coming up with $70 w/ shipping were I found them. @ExitLeft?Anyone have a good link to order them online?
