When using a vicegrip, there's a fine line between holding the nutsert so it can't spin, and squeezing it so hard that it holds the bolt tighter. If you get the bolt out, you can tighten the nutsert (with tool), then add antisieze to the bolt. Also, run the bolt all the way through to make sure the end of the nutsert didn't get damaged.
No issues with the plastic nuts, but I haven't had to do the rears yet.
