This post will help you my lost soul....I was once lost, then I found this forum...Now, I have spent $14K on a Jeep that I bought for $13K....
Disclaimer: I've never run RCVs.I should also ask, what's the deal with RCV axles?
I have a buddy who stepped up to RCVs, because he was regularly breaking outer u joints. He has no more problems with that. I do however wonder what will go next!Disclaimer: I've never run RCVs.
They seem to be really stout axle shafts which are overkill (in my opinion) for most TJs on 35" tires. That being said, I do have a few friends that run RCVs on their JK & JL Unlimited rigs on 37" tires and they seem to hold up very well. Different Jeeps though, different game.
Yes, that would be a concern. I suppose it all depends on how the rig is built and how heavy the driver's foot can get?I have a buddy who stepped up to RCVs, because he was regularly breaking outer u joints. He has no more problems with that. I do however wonder what will go next!
From your description of what you will be doing, the factory carbon steel 30 spline Dana 44 shafts in the rear will be fine. If you want to upgrade because you just want to, Revolution Gear's 30 spline 4340 shafts would be a good choice.
Yes that's fine and a good combination. And you can save a bunch of $$$ if you go for RGA's import version. Its warranty is "only" 10 years vs. Lifetime but they're pretty much the same axle shaft.has something changed? I've seen here and seemingly in several other places that RGA rear axles are 4340 but their site says 4340 for the front and 4140 for the rear.
Hey Jerry are those warrior corners?what do you think of themYes upgraded front shafts are all you need. 4340 27 spline front shafts like from Revolution Gear or Yukon. Revolution Gear would be my #1 choice. No need for trussing, gussets, sleeving, etc. My front axle has none of that and it does trails that would scare 99.9% of Wrangler owners.
And if you saw the trails first hand that my previous TJ's Dana 30 survived with aplomb after upgrading just its axle shafts you'd quickly relax about the whole thing.
These are all with a Dana 30 and Dana 44.
View attachment 274388View attachment 274389View attachment 274391View attachment 274392View attachment 274393
Yes, HTF could you tell that lol? They were fine but being they were steel they were heavy. I later swapped them for Savvy's aluminum corner guards.Hey Jerry are those warrior corners?what do you think of them
I’m wanting to do the round tail lights plus I have some rust under the license plate,(gonna move it to the spare)they have a tail and separate reverse light,do you think those lights are any good,says lifetimeYes, HTF did you know that lol? They were fine but heavy. I later swapped them for Savvy's aluminum corner guards.
What lights?I’m wanting to do the round tail lights plus I have some rust under the license plate,(gonna move it to the spare)they have a tail and separate reverse light,do you think those lights are any good,says lifetime
