Howcome your Jeep is on its side?
He got it from this guy.
That one single LED was enough to upset the balance. Tipped it right over. THATS why I need the second one mounted soon!
If you would run this by the Forum Aftermarket Research Team (F.A.R.T.) we could save you a lot of these headaches.
Also, we found out the reason they build round houses is so cats can’t crap in the corners.
I bet no other forum comes close.
Took my Bestop trektop off. I have only had the front and side windows in for one day but usually have the top on as a safari top for the shade. It was so nice not listening to the top flap in the wind. I was used to it so forgot how loud it was.
I did the same for a few years. We just picked up a SpiderWeb Shade this past summer and its fantastic so I have the top down way more often now.
Was it bank 2 sensor 1? If so, what brand sensor did you use? I replaced mine with an NGK and I still have the same code. Worked fine for about 3 days. I’m thinking I need to buy OEM. Would like to know what others have experienced with the 2/1 O2 sensor.
It was bank 1. The ‘97 only has one bank, not two. I used the NGK.
Back
Top
