So, from the post here, our TJ’s will shut off before the tank is empty. Is this from the computer or is it a pick up problem?
The pump turns off once the Jeep starves for fuel and the engine dies, not before, so it doesn't sit there running dry. I think that's what people are saying or trying to. The pickup is spring loaded and pressed on the bottom of the tank. The screen prevents it from sucking up everything just because of how it's made but it gets pretty darn close. When I've pulled my tank there was a little bit of sand and crap down there that I wiped up with a paper towel. I drove it until the needle was just past the "E" so it was almost empty.
Either what pager said or in my opinion there is simply nothing there to keep running. Reason why i say no fuel is because, if memory does not fool me, i was able to fill almost all 19 gallons into tank.
What ever goes on there, is the reason why you cant apply "running on fumes" to 4.0
Few times that i have ran out of fuel, done is done, that was it, there was no stuttering or choking, no engine shut off and then able to start and limp for a bit . Literally ran like a champ and shut off, any cranking past that was a waste of battery.
