Took it wheeling...
Started the lowering process.. replace passenger spring and shock… 3 more togo…
Reactions: Irun and DuncLJ
Believe it or not the hardest part of my lift was the rear shock bolts. Had to stick a Dremel cutoff wheel up in the hole and cut the welded nuts out of the body blind.
Oh I believe it. Had the same issue with mine. Front lower control arms gave me the most trouble. Ended up cutting them out. Bolt had rust welded to to the sleeve.
Reactions: Ryanoceros
When I told my wife, she said “oh that’s bad!”.
I've learned not to have this conversation with my wife. She can go well over 600 miles on a tank of gas. I'm lucky if I go 240. If the topic comes up, I just change the discussion to, "we should add more plants to the garden!" :whistle:
Control box bolts were shredding my expensive TRE line...
So I moved that sumbitch back over the motor where it came from! The guy I bought it from was all proud that he had purchased a new bracket and moved the thing over the drum. Bad idea...
I had the same problem and ended up grinding the bolts down to a shorter size that would clear the rope.
