Those would probably work. I know you don't rock crawl and all, but I bet you do forest service roads with ruts and washouts, so some articulation will happen, yes? Factory control arms are designed to flex when the clevite bushings reach there max misalignment. The problem I see with those arms is no flex of the arm after the bushing reaches max misalignment. the next thing that would flex is your control arm mount brackets. That would be a bad thing IMO. I could be wrong here, so take it for what it's worth.
