Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life.All that and no answer??
Usually between 1-26.5 minutes, depending on which regulator I have on my LP tank.How long does it take to fill your tires? Does an air tank matter?
Say what now?Once the tank reaches the same PSI as the tire you're now filling both the tank and the tire with the same amount of air from the compressor. I would think that would slow times down, not speed them up
Not saying I'm correct, but what part don't you agree with?Say what now?
I edited my post, there really is an interesting aspect to what you posted.Not saying I'm correct, but what part don't you agree with?
Once the tank and tire reach equilibrium, then the pump is filling both the tire and the tank.I edited my post, there really is an interesting aspect to what you posted.
Got it! My bad, I will stop asking questions on here. I will simply endow you with my vast knowledge. It will suffice, for it is great.Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life.
Yes, you are correct!!!!!! That is why you need a tank, it will rise (PSI) as you stop filling one and go to the other. Unless your OBA is paltry and is struggling at 12psi, sorry if that is the case. Do a "go fund me" thing, I here it works for projects like this.Once the tank and tire reach equilibrium, then the pump is filling both the tire and the tank.
Without the pump involved, how long does it take for a 2 gallon tank at 120psi to reach equilibrium with a 35x12.5x15 tire at 8psi? And what is the resulting equilibrium pressure?
Ummm, #metoo?I’ll time both ways this weekend.
Yes, you are correct!!!!!! That is why you need a tank, it will rise as you stop filling one and go to the other. Unless your OBA is paltry and is struggling at 12psi, sorry if that is the case. Do a "go fund me" thing, I here it works for projects like this.
If your compressor is getting into the 12-30 psi range (equilibrium) during a fill with a tank, then ya, it makes no difference except the first part of your fill which is from stored air and the easiest to push.Once the tank reaches the same PSI as the tire you're now filling both the tank and the tire with the same amount of air from the compressor. I would think that would slow times down, not speed them up
For an outa shape 53yo? Bout a minute. So, ya there is at least 3mins. What is your spry time between tires.Ok. How long does it take to move from tire to tire? How much will this tank fill as you move from tire to tire? How big of a tank to get to a 4 minute decrease in the amount of time squatting? 2 gallons?
About a minute to shuffle 5-6 feet to the next tire. That's a data point.For an outa shape 53yo? Bout a minute. So, ya there is at least 3mins. What is your spry time between tires.
Shuffle is step two. Get off the ground is step one.About a minute to shuffle 5-6 feet to the next tire. That's a data point.
We know it takes about a minute to shuffle 5-6 feet over to the next tire. I know it takes a York a few seconds to fill a 2 gallon tank. That leaves about 55 seconds of cool down time for the pump between tires...Also, if it is faster; is the time saved worth the wear/heat of running the compressor continuously vs. letting it shut off between tires?
