New headunit and speakers. Crutchfield makes it too easy.
Kicker 5.25 roll bar and dash and JVC head unit... sounds much better and happy to finally have BT.View attachment 172841
what model head unit is this?
Got it back after selling it almost 2 years ago.
I did, it was a scratch and dent. Full length "maxxhaul" for receiver hitch. Got it for like 20 bucks (way cheaper than a bending die for square tubing that I'm gonna use once). Cut about nine inches out of the center, welded, and built up brackets.You said you picked that rack up from Amazon?
Nice!Got my roll bar, tailgate, and CJ grille back from media blasting. Primed everything and got a coat of paint on it. Put a second coat on today. I'm going to paint a Colorado flag on the CJ grille.
i hope the kicker speakers sound great with the JVC units i just bought the cs 6.5 rears and 5.25 front to go with this jvc unit i just put in a month ago JVC KD-T900BTS ill be installing in a week or so after returning from the lakeJVC kd-x470bhsView attachment 172963
Back up to post 13374.You said you picked that rack up from Amazon?
Sooo I'm guessing your rear view mirror is redundant now....?I had to cut, weld and modify some more, but I got the fuel can to fit.
Not bad, the entire rack cost about $60.00
thanks i was thinking id add poly to the rears and see what i can do with the fronts. my center has cutouts for sub but wasn't installed i have been looking at powered subs for the future.for now id like to be able to use and hear the audio. Also to stay on subject of the thread i changed the oil todayI have the same kickers front and back along with and older JVC. They sound great!! I do have the speaker pods in the front and added Poly fill in the sound bar, tightens everything up. I also added a SW11 kenwood powered subwoofer, it rounded it nicely.
Oh....didn't know you cut it down. I liked the size, just right for my ATV trailer.I did, it was a scratch and dent. Full length "maxxhaul" for receiver hitch. Got it for like 20 bucks (way cheaper than a bending die for square tubing that I'm gonna use once). Cut about nine inches out of the center, welded, and built up brackets.
