I got the bushing pusher tool stuck in mine last year. Still stuck, got a replacement from daveys jeeps.Well, well well there's always one in every batch, just can't go with the flow
I also found if you overtighten the hinge nuts, you’ll never need them again.Honestly I did not expect it to be that hard. Had to sand the hinge on driver side to get the plastic bushing in. I got everything thing in ok, had to remove pass side bracket and drill it out. Tried to remove driver side and top torx stripped out.
Now.... Where did I put those hinge nuts I took off a year ago?
Now that was funny.I also found if you overtighten the hinge nuts, you’ll never need them again.
That's pretty close to where I'm looking in MT area (if we draw)..planning to head to the Dillon area. We love hiking & hunting timber. We went way east MT two years ago, miles city, it's all open and road hunting trying out more west now.I do hunt, and I moved here from Montana. I am also lucky to have some great private/public access over near Leadore Idaho.
I know this is directed at Boom. He has a wicked build.B00mb00m. I'm having 2nd thoughts on the JK axles for my TJ-R. I have another set of TJ Rubicon axles I'm working on and I can either strengthen these for 37's or continue the F&R JK Rubicon axle build. I'm planning a 100" stretch and around my woods, narrow rigs squeeze through trees and can take several lines JK's and JL's can't.. While vice-versa happens on uphill obstacles. Did you ever, at any point, regret going with wider Jk axles? Or did you regret not going even wider with 1-ton axles?
I have no regrets with JK axles for the reasons I bought them for, except that now i want tons only because JK axles are not bulletproof. I get to wheel with guys whos axles are bulletproof, they can push with no worries and i have to be careful. Thats going to eventually be a problem. I would've ended up with absolute dogshit suspension and steering for my pricepoint and tons. Rockjocks were NOT an option budget wise. I've been able to incrementally build and that has been a help.B00mb00m. I'm having 2nd thoughts on the JK axles for my TJ-R. I have another set of TJ Rubicon axles I'm working on and I can either strengthen these for 37's or continue the F&R JK Rubicon axle build. I'm planning a 100" stretch and around my woods, narrow rigs squeeze through trees and can take several lines JK's and JL's can't.. While vice-versa happens on uphill obstacles. Did you ever, at any point, regret going with wider Jk axles? Or did you regret not going even wider with 1-ton axles?
You got a build thread LJ? I'd like to read about 1 ton work. What year sterling got you 65.5, 99-04?I know this is directed at Boom. He has a wicked build.
I just finished my 1ton swap and narrowed my front KP60 to match the rear Sterling (approx 65.5" JK width). I live in Vancouver , BC (PNW) and found that it is just perfect for the narrow tree trails that I used to run on Rubi44s, BUT have that extra width for stability etc..
Hey BoomYou got a build thread LJ? I'd like to read about 1 ton work. What year sterling got you 65.5, 99-04?
Sounds good I'll ck out your club writeupHey Boom
I kind of documented my build on FB and my local BCjeepclub.ca
I didn't have time with the kids to make one on here. Sign up for Bcjeepclub.ca and you can see my build. IF you would like to chat, you can always call me (PM me ).
I took axles from a 91' F350 Diesel SRW
Very coolFinished the power wheel jeep Barbarian for my boy on his birthday today. He's a happy kid!
Here's the video I used for the electronics in case anyone wants to do an M18 swap.
I also wired in some amazon fog lights.
That’s pretty cool, Boom. I bet that beast moves.Finished the power wheel jeep Barbarian for my boy on his birthday today. He's a happy kid!
Does it ever stop raining where you are?I'm tagging along with the local wheeling club (tamers) tomorrow at reiter. Should be some easy wheeling I just HAVE to get out and try my atlas! I haven't wanted to wheel in the rain but fuckit it won't stop raining whatever.
I have friends in Norway, where they have a saying. “There is no such thing as bad weather, only bad clothing.”No, no it doesn't EVER stop raining here!! Its ridiculous...
