Control Arm bracket before and after. I think I still need to bend the left side out. I don’t know how to bend it up from the crease. Any ideas?
I've made some wood blocks to fit in a correct size mount, wedged it in place, then used some body work hammers to shape it.Control Arm bracket before and after. I think I still need to bend the left side out. I don’t know how to bend it up from the crease. Any ideas?
Great ideaI've made some wood blocks to fit in a correct size mount, wedged it in place, then used some body work hammers to shape it.
You can also use large "C" clamps to help pull it in place.Great idea
Another good idea! Thank you so much! My mini skids are coming soon and I want to get that bracket as perfect as possible before welding the skid on.You can also use large "C" clamps to help pull it in place.
It's a nice upgrade, 2" is a lot of clearance! If you ever go BBK, don't forget to ask for the reverse taper.I ordered the parts for the TR flip. Want to knock that out in late March or early April.
https://www.tmrcustoms.com/products...GIl5LaQKbOS9XuLTAKjMJJtFGfTOVdOhoCt5oQAvD_BwE
https://www.shop.blackmagicbrakes.c...rackets-and-Gussets-SWAYBAR-LINK-BRACKETS.htm
Without the great videos by BFH Garage I’d be intimidated. Great work over there!It's a nice upgrade, 2" is a lot of clearance! If you ever go BBK, don't forget to ask for the reverse taper.
Thanks for that tip! That is something I would not have known.It's a nice upgrade, 2" is a lot of clearance! If you ever go BBK, don't forget to ask for the reverse taper.
Wow that came out great. I'm debating between ace hardware black or a simple clear coat over the steel. I like the color you picked though.Painting the 4340 Heat Treated Tie Rod. I’ll install it when I do the TR Flip.
Prepped (note the spirals in the steel ???)
Self-Etched Prime
View attachment 315043View attachment 315044
Top Coat
View attachment 315181View attachment 315182
Clear
View attachment 315183View attachment 315184
I was debating the clear coat vs paint myselfWow that came out great. I'm debating between ace hardware black or a simple clear coat over the steel. I like the color you picked though.
Clear coat alone would look fantastic!I was debating the clear coat vs paint myselfView attachment 315190View attachment 315191View attachment 315192
This Dewalt blade on my Ridgid jig saw. It worked better and quicker than an angle grinder for a straight cut. I could not make curves and such.What blade did you use for the jig saw? The cut looks great!!
