Hello all!
I have a 2003 TJ which has failed at the white/yellow plastic piece which connects the filler neck to the gas tank. If I go on any inclines; I can leak a substantial amount of gas so this is prohibiting use of my Jeep for Jeeping! As you can surmise, this is a grave problem.
In searching for options, it looks like Jeep doesn't have any stock of these gas tanks, nobody makes a normal aftermarket solution, and the used prices of these are exceedingly expensive in my local area. I had even inquired about a used one parting out on Craigslist and the individual broke it in the same spot trying to remove the tank.
I live in an area which requires emissions testing so I can't just do away with the EVAP system.
Options:
1. MTS makes a new polyethylene 97-02 tank ($600) - could I even make this work?
2. Barnes 4WD 13 gal. stretch tank ($800) - looks like I'd need to acquire 05-06 style fuel pump as well.
3. Motobilt Aluminum 14.5 gal. stretch tank ($800) - looks like I'd need to acquire 05-06 style fuel pump as well.
4. GenRight 24.5 gal. tank ($1,800) - maybe fits 03-04 style fuel pump but requires a 1" body lift.
5. Local Used ($800)
Is there any other options that I am not considering? Have others been able to get pre-03 tanks to work on 03-04 while retaining EVAP features?
Thanks in advance for any help y'all can provide.
Cheers
Options:
Cheers
