Hopefully you’ll find something, but keep in mind if the timing is significantly off to the point the pcm can’t compensate you should see an error. If the ASD relay is not dropping out during cranking or when it is attempting to run a catastrophic timing error doesn’t exist.
I just ordered a fuel pressure tester with the T adapter it will be here tomorrow i think thats the next step prob to verify i have enough pressure
