3 wire led light help
ccmf22
new hampshire
I’ve wired up my 3 wire 3/4” led light to my front turn signals. They function correctly when the headlights are off. When I turn the headlights on they don’t flash. How do I wire these up correctly? My intentions are to remove the corner/marker lights.
2001 tj
Thanks
You have to dig back in the harness and eliminate the floating ground.
If you dig back in the harness far enough you will see where they merged the side marker and turn signal together. You will have to take that connection out and splice everything back together in parallel.
https://wranglertjforum.com/threads...talism-or-blackjacks-98-se.45310/post-1047181
Thank you! I found the floating ground and rewired! LEDs function perfect !!
Reactions: JMT and Blackjack
