Mine is a ‘97 that came w/ the 4.0 and an AX-15. When I bought it, it had a 3” lift, 31s and stock 3.07 gears. It was kind if slow on road but I was just stoked to have it and didn’t care. Then I put 33s on it and it started to seem slow. So, before really knowing much, I had a shop do F/R trutracs and 4.11 gears. Big improvement but, could have been a little better (4.56 is a common rec here for that combo and its a good one). Even 4.88 might be OK with the stock motor. However, when the stroker was in, 4.11 seemed perfect on the street. E-lockers also happened as my trutracs were not effective when lifting a wheel. My other problem was rock crawling with the 231. I’m in the middle of an atlas 2 speed 5.0:1 install to fix that. But I’m also going to re-gear the axles due to the new 35s (prob 4.88).
I’ll probably end up with a TJ-6 on tons and 42s. Gearing then will depend on how big the V8 is…
